Front leaf spring question
Started by 36 Ply, July 18, 2008, 01:17:19 PM
Jim Cno-
Thank you for reproducing the spring info; it is a big help.
I should have just done this in the first place. It looks like if you have a well on one side but not the other, you have two different part numbers. Otherwise, only one...
Hope this helps.
Elmo and JIm Cno, thanks,
1936 P-2 convertible
Serial No. 28273xx
Detroit plant
Body number  80417xx
I'm looking in my parts manual right now. It looks like they used a lot of different parts numbers in '36. Most are the same on both sides but some are different.
Let me know if it is a P1 or P2, body number, assembly plant and body style and I'll see what it says for your particular car.
Pat i can't answer your question as i dont have a 36 Plymouth parts book , but i do have a 36 Dodge one and i would think they would be very much the same ( although i couldn't guarantee it ) it gives a different part # for right and left spring , whether it is because they are different lenghts i don't know.
Are the front leaf springs on a '36 Plymouth the same length or different lengths?
If they are different, which one is longer, driver's side or passenger side?
