fuel syslem
Started by Johnr72hd, May 31, 2012, 03:46:10 PM
Yupper, it was on the car when we got it almost 24 years ago, works just fine  :) :)  I may be mistaken, but I also think it is correct also for 1940
#5
John, Attached picture of my 39 model, the linkage looks the same as Bobs 40, maybe your spring is on the same place as the 39. Blow the picture up a bit and you can make out the spring, between the soft plugs.
Bob, shame on you, is that a dry type Air Cleaner, not an oil bath. lol
Take care guys,
Here are two photos of my linkage to the carb on my '40.  I won't say it is correct, the old thing runs good and still gets from Point A to Point B and back again
Hope this helps,
Johnr72hd
Sorry about that; a 1940 Ply with a Carter carb.
It would help to know what kind of carb on what year, make of vehicle
Johnr72hd
I need informaltion regarding where the spring is located on the carb linkage to keep
it in the off position, prior to stepping in the peddle..
