How can I move the crankshaft without starting it?
Started by Plymouth1931, October 06, 2009, 10:42:14 PM
You may also be able to get a socket on the crank pulley bolt and run extensions through the opening you were talking about.
That bolt has changed sizes over the years so you'll have to look to see what size socket fits.
Plymouth1931
remove the spark plugs and turn it withthe fan while putting some pressure ont he belt. should turn over easily without compression.
Plymouth1931
 ::)I bought this 1936 4dr plymouth and want to know how to check if engine is siezed. I notice that there is a ""crank "opening in the front.WAs this used? Also it looks like the bell housing is cracked..Can it possilby be repaired? Thankyou in Minnesota
