Rewiring in need of a diagram and advice
Started by 84400, February 22, 2007, 11:16:00 PM
Got them both (again, this is for the car, not the truck, but they should be close) which one do you want. Email me and tell me which one you want and I'll email the file back to you, it will have better resolution than what I can post.
84400
WOW thanks alot!  these should help.  Jim, thanks for scannign and posting a link.  is that the closest you have to a 1941 or 1940 diagram.
thanks again for all the help
1984 chevy c-10 small block 400 (hot rod)
1962 wheel horse 552 (all most restored)
1978 case 210 bored .030 over(restoration project)
It's from a generic repair book that covers 1940 to 1955, so I assume it could be specific to any one of those years.
I give up, what IS the matter with the 8 cylinder distributor?
BTW, I have quite a few different manuals (for cars) so if anyone needs a year specific diagram from 1935 to the mid 50s, I'd be happy to scan it and post it. Also, if you follow the link over to my Photobucket account, you will find pages of specifications for Plymouths of those years.
Jim Cno, beautiful diagram, which years does it cover? what?s the matter with the 8 cylinder distributor?
Greetings Go
Doran Johnson
Here is a picture of a wiring diagram. It tells you the wire sizes and I would think they would work just fine on your truck.
http://smg.photobucket.com/albums/v76/JImCno/Fix%20Plymouths/?action=view&current=wiring_diagrams.jpg
84400
Well i have dicided if i get this 41 ply truck i have been looking at i will keep it 6v.  however the wireing was all chewed by mice or falling apart so the PO cut it out! So there is no wiring in it as it sits.  So I am in need of a wring harness and an idea of what gauge i should use.  I know on the battery cables i nned to use thicker ones hen the 13v opnes but what about for wring to the headlights and gauges?  would i want to use 14 gauge?
Thanks on any help you can give
