1941 Wipers
Started by Mike41, February 27, 2013, 07:22:38 PM
Mike41
Lindsay,
Just sent another email, let me know if you do not receive it.
Mike
Lindsay McConnell
Mike,
Received your request a few months back but nothing since then. My ISP has decided that "they" should be in control of all spam filters, not I.... I am not real happy about it. Try me once again and see if it will find me. Sorry about this.
Lindsay
Mike41
Lindsay,
Did you receive my email regarding the wipers.
Mike
Lindsay McConnell
Plymouth and Dodge, for 1940 and 1941 do not interchange. Gotta stick with Plymouth stuff on this item.
Opps, I'm bad, I knew the difference but forgot to mention it.  Thanks Jim
The PT125 electric wipers were also optional but they are completely different from the car.  The car has the wiper mounted at the bottom of the windshield - the PT series wipers are at the top.
Mike,
I can't answer your question, but according to my Master Parts list book, the 1941 PT125 had electric wipers, but not the cars.  Also according to my book, like Lindsay mentioned, all the parts from the 1940-1942 will work.  My book only goes to 1942.
I would suggest you contact Ply 46 and bigaadams who are both members of this forum, they should be able to steer you in the right direction
Hope this helps.
Mike41
Thanks for the replies, I would like to go with electric if possible, do the Dodge and Plymouth setups interchange?
Mike
I do know that electric wipers were optional on the Dodges in the early '40's but not sure about Plymouths, I do know that the '40 Plymouth only had vacuum.
Lindsay McConnell
Mike, You can expect to get away with a set-up from any closed car 1940 Plymouth, but that is it. I do not know a thing about the electric, aftermarket set-ups, so maybe someone else can chime in on that.
I am about 98% sure that I have a total set-up, including motor, transmision arms, towers , bezels, nuts.... in current stock. If interested, drop me a line. I will head out to the frozen tundra to search the boxes (burrrrr).
Mike41
I just acquired a ?41 P12 and it is missing the entire windshield wiper system, the only thing left are two holes in the cowl. The question I have what other years(if any) would fit and I have seen both vacuum and electric set-up, are they interchangeable.
Thanks for any information.
Mike
