Autolamp 9000 turn signal switch
Started by Tony D., November 06, 2012, 09:52:24 PM
Tony D.
Thanks Bill,
I already have the diagram from Painless Wiring.  I'm looking for a diagram or photo of where the different colors are soldered at the contacts of the switch itself.
tony
Tony,
I found this on the internet.  Hope it helps.
Tony D.
Hi All,
Does anyone have one of these aftermarket turn signal switches in a car or truck?  I had to rewire the switch from the inside out (the original wires were frayed and colors were faded) and I think I have the correct colors at each of the contacts on the switch itself.  I can't figure out where the wire for the indicator light goes to.  The switch is in a P19, and I'm having a problem with the brake switch.  The brake lights are always on, the car hasn't been driven yet and the owner believes that he improperly adjusted the master cylinder push rod.
I appreciate any help, especially if someone has a switch that is being restored.
Thanks,
Tony
