Looking for '35 PJ coupe parts
Started by TrueReb, October 27, 2012, 12:08:35 AM
TrueReb
Thanks guys, appreciate the info. I saw that headlight switch and thought the same.
I have figured out most of the wiring and have a correct wiring diagram for a 35 coupe now. It's a two man job with the meter I have so I'll get my son to help.
I've gotten the heater operational, but the radio is putting out static, which is good. Looks like I need to look at the antenna connections or something.
RichW
#3
You can download the entire radio hook up and mounting instructions at www.nostalgiaair.org . Just do a search of the radio model number.
There is a correct headlight switch on ebay  right now. The price seems a little steep though.
The crank mechanism appears on ebay every now and then also.
1935 PJ Deluxe
1969 Barrracuda
1929 Model A Leatherback
1928 Model A Roadster Pickup
1924 Model T Coupe
1949 P-18 Convertible
The best way to figure out your switch would be with a continuity tester. Pull it out to the first detant and that would be for your parking lights. The second would be your headlights. Looking at the '36 wiring diagram, one lead goes to the dash light switch which you wouldn't use.
The heater mounts to the firewall under the dash on the passenger's side. There will be two pipes protruding into the engine compartment. One would hook to a hose going to the rear/right corner of the head, the other goes to the elbow in front of the thermostat housing.
The radio would mount on the firewall on the drivers side and should have cables that mount to the radio face that would mount in the ashtray hole in the dash.
I hope this helps.
TrueReb
I'm looking for the following parts for my 35 PJ Deluxe Cpe:
panel lamp switch
windshield crank out mechanism
radio hookup instructions
correct headlight switch and knob (I have a new '36 5-pole switch, but can't figure out what pole serves what system, like pos. 1 probably parking lamps, pos 2 ?? pos3 headlights?)
correct heater hookup instructions
