H/C cylinder heads from EMI - is it a scam
Started by Mark Steck, October 02, 2012, 11:33:45 AM
Mark Steck
Unfortunately, mine is beyond the center punch fix.
SD Glenn
Mark, depending on where your head is cracked....  The head on my 39 Roadking is cracked, I followed down both sides of the crack with a center punch, closely spaced, tapped lightly with a hammer. I sealed the crack completely.  It might not hold if this was a pressurized system but for now it works great, not even a seepage, hot or cold.  My crack was on the outside surface however.   Hope this helps. I don't know anything about your supplier, good luck.
SD Glenn
SDGlenn
Mark Steck
For many years, EMI in El Paso, TX has advertised High Compression Aluminum heads for early Plymouths in the bulletin. I have been needing one, since the head on my '34 PE is cracked. I finally got around to ordering one from them, but now I am concerned about whether it is a worthwhile supplier, or a scam. Does anyone have experience with this company?
