1936-1942 Wheel Cylinder Pistons
Started by brucepine, September 02, 2012, 10:37:53 PM
brucepine
Thanks Tod,  somehow I knew you would be the first one to help me out.   Bruce
38 P6 Touring + many Valiants
Quote from: brucepine on September 02, 2012, 10:37:53 PM
Will someone please explain the mechanical reasoning for each wheel cylinder to have a smaller diameter piston/cup in the front and larger piston/cup in the rear?  Thank you
As the drum turns, it will tend to pull in the front shoe (self-energizing) but that is not true of the trailing shoe. So to balance the braking between the front self-energizing shoe and the rear, they put a smaller piston in front.
brucepine
