Clutch Housing /Fork Seal Wanted -'36 on
Started by Lew, March 21, 2011, 10:43:00 PM
Found original seall; made quick paper templates, and drawings of leather and metal support in the posts are direct match of the original.
Again many thanks for all the replies.
LR
The metal for the frame is fairly thin. It is very pliable but holds it's position when bent. It is not spring steal.
The cover is held to the clutch fork with a split rivit.
Hope that helps.
Mark
I'm not sure of the gauge of the metal for the bracket. I would think the thickness of galvanized duct. It's been a while since I've made anything with a coffee can lid. So much of the packaging material these days is so flimsy I'm not sure I'd trust it.
It would have to be stiff enough that  bending over the tabs will hold the boot in the hole.
I also don't know about the rivets. Even though I have these templates, I've never actually made one. Way too low on the priority list.
RichW
Bernbaums had them for sale a couple of years ago. I got one for my 35.
1935 PJ Deluxe
1969 Barrracuda
1929 Model A Leatherback
1928 Model A Roadster Pickup
1924 Model T Coupe
1949 P-18 Convertible
Thanks Jim for the scans and the Ply. Club site!!; was able to print exactly and can use as templates.It appears that 2 holes/tabs get riveted to the clutch fork? Also, what gauge is the metal? Is it spring steel which is hard to cut?  Come to think of it, It looks like a smooth coffee tin lid may work and could be cut easily and retain its shape?
Lew, Check your email. I sent you patterns to make the clutch boot and bracket. Heck, I'll just post them here so others can have them too. I don't remember who originally posted these so I'm afraid I can't give proper credit but this little bit of text was with the picture files...
QuoteThis is a scan of a boot actual size. The overall length is 8 1/4 inches, if it doesn't print out right. The two straight sides are overlapped 3/8" and sewn together. I'll try making one to see how it works.
Jim Yergin
I think I have seen them for sale on eBay.
Jim Yergin
Would like to purchase part no. 655466, leather (or similar) seal and metal insert for clutch fork to housing. Understand it was used thru 'the '50's. If not available, any photo or drawing of the metal insert would be helpful as we may be able to fabricate that and the leather portion. We've tried some vendors to no avail.
Thanks, Lew
