1940 Plymouth overdrive trans???
Started by ryanwheelock, October 13, 2010, 11:08:45 AM
The overdrive you describe was available on Chrysler but will work in a Plymouth. The front case is , to the best of my knowledgr slightly different.  Same is true of the more popular R 10 found in Plymouths 52-56 and will bolt right into a 40.
As far as I know (from this forum) You need another trans with a hole for a connection rod or something similar. Ask George Asche : he is expert!
Overdrive and transmission:
George Asche
Asche Mechanic Distributors
George Asche
1693 Fertigs Road
Venus, Pennsylvania 16364
(814) 354-2621
Greetings from cold Germany,  50 deg. F (10 deg C) this evening...  Go
ryanwheelock
Was there an overdrive option availble for 1940 plymouths back then??  I've been reading a bit about the R-7 unit.  Looking for a bit of info about it and would it work in my car.  Can I buy just the overdrive and add it to my trans or would I need to by a used one with the R-7 already on it??
Thanks for your help
Ryan
