Carter BB-1 Carburator (for PB) - will it fit on a 29 Plymouth?
Started by johnRFain29U, April 19, 2010, 11:51:27 PM
Quoteespecially if it has an adjustable main jet.
I had an old BBR with an adjustable main jet. How does one adjust these? OR I should ask, how does one know when it is adjusted properly?
FourDoor
The BB-1 on the PB used the same huge stove pipe and box affair as the PA for an air cleaner. They are rare as hens' teeth if you don't already have one. It seems they must of been in the way maybe while trying to inject some gas in the carb to get the engine going? Most to-day have the last piece that went on the 'end' of the 'stack' as their air cleaner now,it fit right on the neck of the carb. I've always thought there is a bunch of those original air cleaners for PAs and PBs hanging on nails on driving shed walls all over.
It might need an adaptor but this is an excellent carb to use especially if it has an adjustable main jet.  dp
johnRFain29U
Will the Carter BB-1 Carburator (for a PB) fit on a 29 Plymouth?  The 29 Plymouth carb to intake manifold bolts are 2-3/8 inches apart.
What type air filter did the BB-1 Carb use?
