1936 plymouth transmission
Started by ParkBear, April 13, 2007, 05:42:34 PM
You don't need any special tools. If you don't have a Motor's manual from that time, get one. It has a step by step procedure for the transmission.
ParkBear
I found another 1936 plymouth transmission off of a 2 door that is in working condition. I'm going to go pick it up tomorrow. I'm passing on the dodge transmission. So I will have 2 transmissions, one that is siezed and one that isn't. Between the two, I'm sure I can get one rebuilt. Do I need a press or any special tools to rebuild this transmission.
After my transmission, I move on to the driveline. I plan on driving the car on the frame. ;D My dad gave me this car as a high school graduation gift 15 years ago. So I have been dreaming about driving this since I was a kid, it has been a long time. To this point, I have completed the engine, frame, front and rear end. I still need to run brake and fuel lines and find a tank.
Any advice or tips on the transmission or driveline would be great.
Mike
Mike
1936 plymouth P2
Currently Being Rebuilt after being in pieces for 18 years
Mike, I'm doing the same thing. I have a '35 and I tore down the transmission just to see what condition it is in. It is a very simple procedure. The one thing that surprised me was when all the roller bearings fell out. I don't think I had ever run into a set of bearings that weren't in a race. I'd recommend getting a small parts kit and a set of gaskets. I'm finding the one part hard to find (at a decent price) is the cluster gear. Mine is slightly worn but it was working before I took it apart so unless I find a source for a new one soon, it will probably go back in.
ParkBear
My thinking was that I would want to rebuild whichever transmission so I would know it would be in working order when I drive it. I have never rebuilt a transmission before so I am looking forward trying to figure it out how they work. This is my 1st restoration and I assumed that everything should be rebuilt to avoid problems later when I drive it.  If and when I ever get this on the road, I don't want to rely on parts I didn't verify.
Mike
1936 plymouth P2
 if its a good transmission why strip it down as far as i am awhere they used the same case. put the whole trans in
ParkBear
Mike
1936 plymouth P2
According to a parts book I have, all the parts listed for the P1, P2 transmission match the D2 transmission. I don't have a complete list, and the only part I couldn't match numbers was the clutch gear, but I couldn't match descriptions either.
Parts that match include: countershaft gear assembly and shaft, reverse idler gear assembly and shaft, mainshaft, sliding gear, second gear, and main drive pinion.
ParkBear
Does anyone know what the difference between 1936 dodge and plymouth transmissions. I have the original plymouth transmission but it doesn't shift nor does the shaft turn over. I found a 1936 dodge transmission that works. I'm looking to take the guts out of the dodge and make my original functional. Will that work. I have not bought the other transmission yet. Thanks for any help or advice.
Mike
Mike
1936 plymouth P2
