draft seals, 41 plymouth
Started by notdavidspade, November 13, 2008, 11:59:26 PM
Here is the photo you requested. You will note the toe board is not installed. The draft seal is friction fit to the clutch pedal lever and rides up and down as the pedal is depressed. As Todd already said. The seal is not in effect when the pedal is depressed.
notdavidspade
wow.. thanks!  I would have never guessed that one.
They go on the pedal shaft right where the shaft makes a right angle bend (under the floor board). So when the pedal is up the seal presses against the bottom of the floor board. When the pedal is depressed there is no sealing of the hole in the floor.
notdavidspade
Hey folks,
Can anyone tell me or have a picture of how the clutch and brake draft seals work/attach?  do they go under the floorboard or glue on to it or what?
Thanks!
