41 p-12 coupe doors
Started by MRR41 COUPE, May 12, 2008, 09:08:59 AM
MRR41 COUPE
Thanks Mcvair for the reply and photo. My doors had the drain holes removed over the years. With the drain holes its easy to see how the water would drain out. Now I know why the bottoms of my doors were rusted out. Would be interrested to see that wider seal at the bottom if someone has an original on their car. I'm leaning towards a one piece with the seam at the bottom , i'm going to start rebuilding my drain holes.
Thanks again
Mike
#3
The attached picture may give you some idea about the path of the weather strip on the bottom of the door. I have not seen a piece of original weather strip, but there is a seperate part number for the piece that goes on the bottom of the door. I have been told by the '41 tech advisor that he saw an original and it was a larger (moulded?) piece that joined at the corner with the strip that went around the rest of the door.
I don't think draining should be a problem as long as the drain holes are not covered. The tabs are not the drains. The small slits next to the outside skin are the drains. The tabs keep the weather strip from sagging. I don't know just how they do that. They may slide into the side of the weather strip, or they may fold over the weather stip. I would like to know the answer to that question as well.
I have been told that if rust repair has been done on the bottom of the door, the drain holes may have been welded shut. Apparently that is a fairly common problem.
MRR41 COUPE
Can anyone out there please give me the path the door seal takes on the bottom of the door. This is important because I don't want to keep water inside the door. I'm sure someone has an original 41 with the door seal still intack.
MRR41 COUPE
Can someone tell me or post a picture of how the door seal runs at the bottom of the door. I would not think that the seal runs on the inside of the outer panel  because the water that runs down the glass needs a way out. If it does run on the inside of the outer door panel is the seal notched to let the water run outward.
Mike
