1940 Plymouth first year for Column Shift transmission??
Started by Ping, January 13, 2008, 08:21:04 PM
1939was the first year for column shift, it was offered on Deluxe models but used the same transmission as the floorshift models fitted with a special lid which had a cable selector and change lever built into it.
1940 offered column shift on all models and introduced an all new transmission which is a bolt for bolt swap all the way up to 1956. It proved to be a very reliable unit.
1939 was the first year for Plymouth to have the column shift.  The DeLuxe model was column shift.  In 1940 both the DeLuxe and the Roadking had the column shift.
Ping
Question:   I read in some 1940 Plymouth material that the 40 Plymouth was the first to have the column shift for the standard transmission.......I printed out a sheet for the specs for my 40 Plymouth.  I was told that the 39 Plymouth had the column shift also.  Anyone out there know the truth on this matter?   I know I had a 38 Plymouth with the floor shift.  But, never knew much about the 1939 models.   Thanks, Ping
