Gas Tank Cleaning-1948
Started by scot58elk, April 09, 2007, 10:41:53 AM
Quote from: scot58elk on April 09, 2007, 10:41:53 AM
I am cleaning a gas tank for a "48". The small pipe goiong from within the tank and connects with the gas line is filled with rust any ideas on cleaning that little pipe.
You can use high pressure air to clean the pipe.? Some type of snake might also help.? I recently did the tank in my 48 since I couldn't find an old time radiator shop that still did this type of work.? It seems today that replacement is the main business of a modern radiator shop.
Click on the link below to review my adventure with the P15 Gas Tank.
link below?? ?
http://www.chetscoins.com/1948p15/20045/09182005.htm
PS... Tank is working great.
Cheers,? Chet?
I have taken 3 tanks to an old time radiator shop where they steam out all the crud, solder pinholes and line them with an epoxy based liner.  If the line u mention needs replacing thay can solder in a new one.  I think each tank  was around $100.  Be careful around old tanks-that crud inside can still ignite or even vaporize if u add enuff heat.
scot58elk
