28-29 4 cyl overhaul
Started by SD Glenn, November 12, 2010, 12:29:22 AM
If your car is a 28 it has a Maxwell engine in it. Different than a 29. I have a 28 cpe. and it has climbed the mountains of Maine and Pennsylvania and others. It is just a slow go, sometimes shifting down into 2nd and just chugging up the road. There is no real way to get that 45hp 4cyl to do much more. A little dist advance maybe.
the least noticable visibly and the most baang for the buck powerwise is to mill the head to increas compression ratio.  In the 20 and early 30's 6 to 1 was a high compression engine.  You can easily raise yours to take avantage of today's fuels.  It will also let your run some more spark advance also for a bit more power.  A less restrictive exhaust system might also free up a couple ponies.
You can probably take .050 off the head and .010 to .015 off the block without causing any problems.
You might want to take a look at some Model A forums for some ideas, as those folks frequently make speedsters and hill climb cars from those cars.  Most of the engine mods they do will work for the plymouth 4 banger as well.
Thanks Guys,
I understood the "whimsical" and I appreciate the humor also. No, you are right, and I do not want to take away from the original vehicle. I know about ways to build a hot rod, but that wasn't what I wanted. I want a car I can use as a driver, I enjoy just driving them, we have clubs locally, and have car shows in town (a couple) every summer, most of them camp out a few block from me at a state park, so I see a lot of them, but have not seen a Plymouth, I will probable be the first and I want those folks to stop and look. Does that sound resonable? lol  I will think about the "30U, but I do not think I want to go that route, I maybe will remain a bit weak, guess I am not in a hurry anyway. lol
I am building a "shadow Box" between the bumper halves to put long narrow turn signals in. They will be pretty well hidden until the brake is depressed. I will let you know if that turns out like I am hoping.
Later,
Glenn
It seems there was a horsepower race going on back then. Only 4 years after the 34 BHP model U was made the PC and PD cars were rated at twice that power. A pretty big increase in only 4 years. Given how the 33 is underpowered by modern standards, I can see why you might want to get a bit more out of your 29's engine.
I was wondering if there were parts from a later PA or PB that would allow you to up the power. The PA was rated at 56 BHP which is a substantial increase over the model U. However I think the engines were enough different that it would be a problem making that work. For one thing, I'm guessing that the increased power was one reason they needed to add a water pump.
Glenn,
If you are doing an engine rebuild, the New Style U of the 1930?s used the same engine with a different bore and stroke.  1930U = 3-5/8 x 4-3/4 for the result of 196.1 cu in.  This added an additional 14 hp.   The 29U as it is, is geared to be able to climb hills and back roads.  I am not sure if this change would be of any great advantage to the overall driving speed or efficiency.   It would require changing the crank and the cam.  Not sure if this is easy or not.
My comment was due to the fact that the POC as a club doesn?t favor modifications from stock originally.  It was a whimsical way of saying I don?t think you might receive much support here for this type of change but I might be wrong.
Good luck, Chet?
Am I reading anything in the reply I got...... lol
Are you suggesting I don't fool with getting more power...
Perhap just with making sure the distributor and carb is working right I should be OK, how does that sound. I was kinda hoping for a few tips on things that would make it better. I don't want to change the car from what it is supposed to be, but to get the max out of what I have..........
Glenn
Glenn,
Asking that question here is like asking the Catholic Church to do a Bar Mitzvah.
Good Luck,  Chet?
I know I have a slight rattle in my engine, and I have not dropped the pan yet to check it out, but,... Has anyone out there ever done any mods to this engine to get a few more HP. I could use them, we have a few hills around here (SD) If I have to pull the engine I would like to try a few things while it is out.  I still have not driven this car, but  I do have the brakes, brgs, seals, etc finished......... Thanks
Glenn
