fuel sending unit
Started by MAROTTA1932, December 21, 2006, 05:54:48 PM
Dear Frank,
did You get Your sending unit to work? Did You write the ohm down? As nobody here knows the resistance, it could be good to put it here. Greetings! Go
virge55
hi David saw this on the board and was wondering if you happen to know there web address? i've looked but not found it.thanks for ya time
virge
I have never measured the ohmage on that particular tank unit but there is a universal sort of aftermarket tank sender available here (western Canada) through Princess Automotive's " Powerfist" brand which operates the early Chrysler gauges quite satisfactorily and fits into the tank with a minimum of fuss. It costs about $25.
MAROTTA1932
My name is Frank and woundered if anyone new what the ohm resistance reading should be from full to empty for the 1932 Pymouth PB fuel sending unit.
I am having it rebuilt and would like to check it when it comes back.
Thanks,
Frank
