Engine Running Rough
Started by Mick54Ply, January 16, 2007, 12:23:37 PM
Carla
Hi, Mick,
I had occasion to deal with a pre-war Plymouth with an identical symptom last year........ its a good example of the silly little obscure things which can go wrong.
In this instance, the car's owner had fitted new points to the distributor. The points were the correct ones, and best quality, in the old 'Standard' make, which uses both a steel point-spring and a copper contact strip. It turned out that the owner mis-placed the steel spring, and assembled the points as tho the copper contact strip, which did have a bit of 'spring' characteristic, was the point spring. The engine ran fine at idle, but ran erratically above 1200-ish or so. The 'cure' was simply a good point set.
There is, actually, quite a 'rogue's gallery' of little oddments which will cause this class of problem........secondary wires, as you found out, a partial failure of the wire or the insulation of the tiny primary wires inside the distributor, an intermittent condenser failure, and, one of the more seemingly improbable, the coil itself will sometimes, albeit rarely, develop an intermittent internal problem.
Sometimes that symptom will be caused by intermittent low voltage to the coil, from worn contacts inside the ignition switch, or a corroded terminal in the wiring anywhere between battery and coil. Sometimes a wire terminal may be clean enough, but, over the years, people working on the car had flexed the wire enough to have many of the wire strands break, so that the wire is the equivalent of a badly under-size wire......that is, the equivalent of having a dirty big resistor in the circuit. Sometimes a wire will have been damaged in some unobvious way, so that it may look good, but act as a resistor.....check voltage under load at both ends of the wire, or ohm out the wire......any measurable resistance is too much.
One of the simplest diagnostic tools for ignition problems is a 'test coil'......simply a known good coil, with a bit of bent steel wire taped to the shell with which to hang it from the bonnet stay rods.
Jump the test coil direct to the battery terminal at the starter, and to the primary terminal of the dist, taking care to wire the polarity correctly. Plug in the dist centre secondary wire, and see how it runs. If that makes the difference, you've quickly isolated the problem to the coil and the primary wiring feeding the coil. If no change, then look in the dist, secondary wiring, plugs, etc.
Have the dist out and go through it, verifying the centrifugal advance weights work freely, the little primary wires are good, the vacuum advance diaphragm works normally, etc.,
There is an easy way to verify timing on the Chryco flat sixes. Look on the engine head, over #6 cylinder, and you'll see a 1/8" NPT pipe plug. Remove the plug, and use a small drill to ream out the carbon from the hole into the cylinder. Make  up a little improvised tool from a brass tube fitting with a 1/8" NPT end, and a bore to suit a bit of 1/8" diameter round stock, allowing free travel but little side play. Cut a pin from a  bit of 1/8 brass or steel round stock about 3-ish inches long, and deform a spot near one end, so that it surely can't slip through the fitting.
Put the improvised tool into the tapped hole in the head, and observe that, as you turn the engine (spark plugs out) that the tool follows the rise and fall of #6 piston.
Set up a dial indicator on a magnetic base, to read the travel of the pin as it follows the piston travel, and, rolling the engine over several times, set the zero on the indicator at exactly the highest point of the reading.
Roll the engine over until the indicator reads 'x' thousandths before the zero, with the piston coming up.....decide the 'x' for yourself, .010 or whatever. With the indicator at 'x' before zero, scribe a line or make a centre-punch mark on the front pulley, at the timing-pointer. Continue to roll the engine over until the indicator reads that same 'x' after zero, that is, with the piston going down., and make another mark. Top Dead Centre, or TDC, is half-way between those marks....with any luck, you'll find the original timing marks by cleaning/polishing the pulley.......if the marks are missing, make your own TDC mark. Replace the 1/8" pipe plug in the head.
Note that cyls #1 and #6 are at the same position of the crank, so you have TDC for #1, the timing position.
Roll the engine over until you feel compression on #1, then continue until you reach TDC. The engine is then at TDC #1 firing, the basic timing position.
Set the distributor with the points 'just breaking' at TDC #1 firing, (rotate the dist in its normal direction of rotation until the points are closed, then turn on the ign, and, taking care to be slow, gentle, and careful, rotate the dist against its normal direction until the points break......you'll hear a little 'tick' and/or see a tiny spark) Snug the distributor holding bolt, assemble the cap/wiring noting the rotor position at #1 TDC firing for the #1 wire, then assemble the others 153624, as Elmo has noted.
The engine will run well with the basic timing at TDC. Some Chryco flat sixes are specified for TDC, some for 2deg before, etc. With the timing at TDC, try setting it slightly advanced, and go climb a hill with the car. Advance a degree or two at a time until you get a bit of pinking, then retard back slightly. Its perfectly alright to experiment a bit with the timing, until the engine feels as 'lively' or 'responsive to throttle' as you can get, but don't allow any pinking under acceleration or under load on a hill.
cheers
Carla
If, after following Elmo's procedure (and making sure the distriutor cap is not cracked and there is no evidence of carbon tracking from one terminal to another) you still have the problem, try replacing the capacitor (condenser). I once spent hours on an engine that behaved as you describe and the problem turned out to be the capacitor with an intermittant loss of ground.
If none of the suggestions work, and you are positive you have timed the engine correctly using the correct firing order, and plug leads following the correct distributor rotation, it is probably time to pull the front timing cover and check to see if you have a very worn chain and sprockets with a resultant chain "jump" that has affected the valve timing.
Hi Virge    It definately sounds like timing to me, have you had the spark plug leads out ,if they are not right they will cause the same problem you car has. To check , go through all you have done ,ie #1 to the top etc, when #1 piston is at the top remove the dizzy cap ,the rotor shoud be pointing to #1 spark plug. place the cap over the dizzy loosely ,#1 wire should go in the position in the cap that the rotor is pointing to, replace the other wires anticlockwise 153624........Rex
virge55
hi was reading this and it struck a chord im having timming probs on the flat six and have done all the things suggested by elmo to mick and NADA! now i dont have any timming marks to check off but all new points etc dizzy in correct way round spit back from the carb is all i get anyone any clues? i've been taking the first piston to just before tdc as it's 2 degrees before and tryin' it like that abit hit or miss but i figured it would rum lumpy and i could go from there . i.ve a great spark so thats not it and judging by the amount of fuel spat all over the place from the carb it aint fuel either! thanks.
virge.
congratulations for Your success! - Our hobby is always full of surprises.
Funny, that the cables were guilty as their bad  ign tension did not hurt at  idle speed... funny.
Greetings, Go
Mick54Ply
Installed new ignition cables, it runs fine.Thanks.
It could be, especially if you rebored the cylinders, that your engine is running with too lean a fuel mixture. Try bringing the speed up with the choke partly closed. This will enrich the mixture. If the engine runs smoothly then your carburetor is too lean. Check the float level and raise it to the upper limit of the specs. It may also be necessary to substitute a larger main jet which would be found in a truck engine or a larger displacement six.
Hi Mick  It sounds like your timing is out, I have always timed my 54 by the manual and have never used a vacum guage. first thing i would ckeck your sparkplug gap it should be .035 then set the points they are .025. Crank the engine to bring #1 piston up on its compression stroke. and stop when the pointer on the timing chain case is in line with the timing mark on the crankshaft pulley, which on the 54 is the second line before the DC mark on the crankshaft pulley. Loosen the distributor body clamp and rotate the distributor untill the points close, then turn it in the opposite direction till the points just begin to open,and tighten the clamp bolt. once it is runnig you will probabely have to loosen the clamp bolt again and adjust it slightly either way till it is running smoothly . do the last step while it is running just be carefull you dont touch any hi tension leads . they dont hurt you just make the heart beat faster.........Rex
Mick54Ply
Overhauled engine runs fine at idle, timming set with vaccum gauge gauge reads 19. The problem is when you open the throttle the engine runs very rough with the odd backfire. I have tried another carb. as well as a distributor, checked fuel pump nothing changes.
