46 Front end alignment specs
Started by brianz, November 12, 2006, 07:44:07 PM
Hi Brianz  these are the factory  settings for 1946 plymouth all models ,preferred caster,degrees,zero.preferred camber,degrees,+3/8. toe in, inches 1/16. kingpin inclination,degrees 5 3/8. i dont know if you have to alter these settings if you are fitting radial tyres. ifitted radials to my 54 and never altered any thing  and have had no problems  the tyres seem to be wearing evenly and it steers ok in fact i think it steers better than when it had cross plys    Rex
brianz
I have a 46 Special Deluxe coupe and am looking for the factory spec for front end alignment.? Additionally, I will be running radial tires and read that the settings would be different - any recommendation for spec in that situation.? Any other considerations for changes from the factory spec.?
