30 amp circuit breaker on a 50
Started by Edwin K., March 17, 2007, 01:54:26 PM
52dodge
The circuit breaker on my '52 dodge truck is mounted on the headlight switch.
I can't tell you exactly where it is but a quick look at a wiring diagram shows that it is in line between the ammeter and the headlight switch. I would assume it is under the dash near those two items. If you follow the wire, you should find it.
Edwin K.
Could someone please give me the exact location of the 30 amp circuit breaker? Thanks.
