1973 440 motor with 727 trans.
Started by cooupe, September 21, 2006, 02:58:37 PM
66 charger
Let me add a couple of interesting facts, the motor home block is the HD one with extra reinforcing ribs, and does have a milder torque cam (easily changed), the manifolds exit in the center and cannot usually be used, but headers and regular manifolds (anything in the 350-440 family ) will work.  The water pumps are the same, but there are two possible housings - l exits on the passenger side, the other on the drivers side (standard passenger car housings).
The transmission is different, it that the tail shaft is a different length than a passenger car but all parts are interchangable.  The good thing about the transmission is that it has HD clutches with extra discs in the clutch pack making it a very strong unit.  You can change the tailshaft and housing for use in a regular passenger car, or have a new driveshaft made and use it as is.
Hope this sheds some light.
I just recently learned that the 413/440 truck/motor home engines are different in several ways from the car engines.  I was told that the heads are different as is the cam, water pump and exhust manifolds.  A friend of mine purchased a low mileage motor home engine to put in his 55 Dodge Lancer. Since the unit had been in a fire he felt  it would be best to have the engine freashened  up, that is how he found out the engine and trans was not the same as a car....   Makes sense, commercial engines are usually designed to get their power at lower RPM's, where-as car engines are designed to run at high RPM's....Bill
cooupe
Have a 1973 440 motor and 727 trans. out of a motorhome with 73,000 miles on it. Block number 3698830. Complete motor and trans. front to back including driveshaft.? $600.00 Call Jim At 810-656-6200        p.s. Yes the motorhome engines are set up a little different,but if you are going to put it in a hotrod you are going to change the cam,exhaust manifolds and maybee the heads anyway.
