1995 Plymouth Voyager back seat/third bench
Started by Bestyet2come, July 25, 2006, 12:36:40 AM
squeeze the handles at the bottom of the rear of the seat, while squeezing push the handle mechanism down, this will release the seat.?Then with an able bodied assistant, pull the seat evenly toward the tail gate.? Then call the body shop as you will without a doubt, scratch both the sill plastic and the plastic bumper cover.? Make sure you have no little ones or important pieces of your anatomy under the seat as it usually lands with a heavier thump than expected thud as either you or your assistant loose your tenuous grip of the imitation mouse fur upholstory on the ends of the seat.
Getting them back into the same place through all the crayons, cheerios, cheetos, crackers, peanuts, dog kibble, change and arcade tokens, pens, golf pencils and M&M's, built up over the past 11 years around the retaining loopes in the floor, sorry yer on yer own........? ???
Bestyet2come
I just bought a 1995 Plymouth Voyager.
Does anyone know if the back seat/bench can be removed?  If it can, can soemone tell me how to remove it???
