Light switch lever on 30U
Started by 30U sedan, July 20, 2006, 02:01:16 AM
David Rainville
I'm looking for the same thing for my 31. If I run across a source will let you know, please do the same. Mines in pieces and plan on presenting the problem to a rather clever son-in-law in hopes of creating  a repro.
FourDoor
Just to clarify= the switch was made by the Clum Co. It was used on all Chrysler vehicles under various part numbers. Good luck in your search. :)
30U sedan
Does anyone know where I can find a light switch lever for my 30U. This is the tube like part (under the horn button) that turns the "chum switch" and has the horn wire running though it. Needing the lever that works the throttle linkage too. Also would be interested in knowing the correct position for these levers (which one is on the right, left, ect.).
