39 P-8 Master cylinder filler plug leaks at the top
Started by DENNIS P NOLAN, May 23, 2023, 08:10:17 PM
Pauls408
You can try teflon tapeon the threads of the plug. You could also go to the hardsare store and find a pipe plug with the same thread. After all, the master cylinder is just plumbing.
my33ply
Mine has a brass washer on the plug. Never had a leak. Good luck!
Richard Cardeccia
1948 Plymouth DeLuxe 4 Door
DENNIS P NOLAN
Hello POC Family
I replaced the master cylinder a few years ago- the filler plug leaks at the top- if you screw it in it would go into the cylinder-
is there something I can wrap around the threads that can/will stop the fluid from coming out??
Dennis
