36 ply. door glass
Started by djbsr, September 19, 2022, 03:22:35 PM
djbsr
Look what your missing out on , you have to get a 36 ! Don ... thanks for input
No, on my '33 the glass simply moves up and down. No forward or reverse motion at all.
djbsr
Hi Todd , on your 33 , does the glass move back before it starts to go down ? On the 36 , i m told that there is a curved channel about 15" long which I don t have . It seems it would go on the latch side of the door in the upper corner. Right now when I crank the window up and it shifts forward it is out of the channel on the latch side of the door. I don t think this is right
On my '33, you:
  • Remove the inside window garnish
  • Crank the window down a bit.
  • Pull the window channels to the inside of the car
  • Crank the window up to the point where the bottom channel clears the door
  • Remove the bottom channel from the riser mechanism.
Maybe the '36 is similar. . .
djbsr
just got my door glass , was missing when i got the car , and i m told that there is a channel about 15" long that sits vertical and is removable . I have the two that are welded in place . Am I missing something ? I think it has something to do with the window moving back from the up position . Help , somebody , anybody Don
