1933 Plymouth PD Part Needed
Started by 33plycoupe, June 13, 2020, 07:22:03 PM
twpoulter
#2
Hi Robert, I have one for my 34PE that I can get sizes from or send you a template if it helps. Have a look and see if it will work on your PD, pretty sure I don't have one on my PD, it's on the lift in my shop so I will check there also.
Tom
[attachment id=0 msg=19934]
[attachment id=1 msg=19934]
  https://ctrestorations.com/
33plycoupe
Help!! I had quite a bit of engine work done on my 33 Plymouth PD coupe this spring. During this time my mechanic misplaced (lost) what I believe to be the radiator dust pan Part nr. 613250. It is the sheet metal part that attaches under the radiator. Please respond if you would have one or know of one for sale. Second choice is a picture of one, because my mechanic stated he would try to fabricate a replica. Needless to say I'm devastated at this loss. Any help would be greatly appreciated.
