Wiper blade refill
Started by Robert5, September 08, 2019, 01:45:35 PM
Robert5
I just saw your diagram. It didn't initially come up.
So, yours uses metal inserts. Mine do not.
I think the difference is Anco vs factory.
I believe all I need is the 6mm x 12" rubber pieces .
I am going to order a 24" piece ( incredibly cheap) are just cut it in half.
Thanks again.
Robert5
Bill....first thank you for doing all that.
Next.....my wiper blades which are torn, do not use any metal inserts. It is just rubber that slides into the metal holders that are a fixed part of the arm.
Bill, do yours use metal insert along with the rubber?
Either way I do believe that 6mm width is the correct number.
Thank you.
O.K., Robert.  Here is what I found out.
The wiper assemblies on my Plymouth are Anco brand, which may or may not be stock.  I took that assembly apart and did some measuring.
If you have this brand, I believe a 6mm wiper refill will work for you.  Check out the photo and drawing.  I did not add the dimension where
the blade is held in the rib, because there was not room to note it.  But, if you compare the photo and drawing, I think, if you can remove the
rubber from the rib, it will work.  If you have another brand of wiper assembly, then I do not know the answer to your question.  The Anco
wiper blades are 12 inches long.
Robert5
Yes Bill. That would be very helpful.
Thank you very much.
Robert,
I will be happy to measure mine for you.
Is the thickness where the blade fits in the holder the measurement you need ?
Of course, there are several wiper blade manufacturers around, so my blade may not be the same as yours.
My blades are probably not what came from the factory in 1951.
Robert5
Can anyone confirm that 6mm (.236 of an inch) is the correct width for refills on my 1951 Cambridge wiper arms? I do mean just the rubber inserts that slide into existing arms.
I do not want to buy the entire arm assemblies.
Thank you all.
