Early PE/PF Steering Knuckle Right
Started by twpoulter, July 05, 2017, 04:32:12 PM
twpoulter
I?ll bring this back to the top, am looking to ship some parts over and would help if I could find one of these. The hand doesn?t matter or the size as I can engineer it to fit. Thanks
  https://ctrestorations.com/
twpoulter
Am in need of a R/H steering knuckle, I know the part as a front stub axle part No 627214 .The one I have has shed a wheel, bent the thread, and then someone has put the castle nut on cross threaded. This is an early one, around April 1934 the size of the king bolts increased by 1/16", the diameter of the top and bottom bush hole needs to be 0.850"
Thanks for looking and hope you can help.
