29 plymouth shift tower
Started by gregorybliss, March 06, 2016, 09:15:40 PM
gregorybliss
Thanks for the info problem i face is getting the old pin out Thanks
I think you may find that it is not so much the pin which is worn but the holes it passes through.
redrill and insert an oversize pin.    Tack welding the old one is a temporary fix at best and will make it really tough to remove at a later date.
gregorybliss
My shifter has a lot of side to side movement, found that on the shift tower there is a pin that is moving causing the excess movement.  How do I get the pin out or can I tack weld it in place.  Thank
