Windshield Gasket
Started by rsp, May 09, 2006, 11:36:12 AM
Dear rsp, You definitely have to use a sealer?
I changed my window panes without it and, told to redo with sealer, found both the  metal side and the glass side completely wet. The car had than seen its last rain 10 months before. It  is stored in a heated, very dry garage..
The rubber gaskets are no way water tight.
You get black sealer which is very easy to peel off where is too much.
Procedure is beautyfully described in my 19P15-P24 Service Manual.
Greetings! Go
rsp
When changing the windshield gasket on a 1939 Plymouth, will I need to use any glue or only the gasket?  Also, what about the back glass gaskets?
