1941 Fuse Panel
Started by bgrumka, August 22, 2012, 05:55:16 PM
MRR41 COUPE
I agree, thanks for correcting me, Mike
Quote from: MRR41 COUPE on August 28, 2012, 11:35:54 AM
The only thing that is controlled by the ign. switch is the coil, I don't have  a breaker on my setup.
On my car the gas gauge is also controlled by the ignition switch.
MRR41 COUPE
There may also be a automaically resetting 30 amp circuit breaker protecting either the input side or the acc terminal of the ign switch.
MRR41 COUPE
Thats the one and only fuse on a 41.
bgrumka
Is there an actual fuse box/panel for 1941 Plymouth mounted anywhere? And if so where?
I know that the fuse for all of the lights is located in the head light switch itself, but not sure about a fuse panel.
