6v Reverse Lamp Switch??
Started by Gaby51, May 18, 2012, 09:14:39 AM
Gaby51
Thanks Scott, I just ordered one.  Yippee!!!!!!    :D
Scott_W
This is where I bought mine. Screws into the same spot on 3 speed or overdrive.
Only $25.
http://vintagemoparts.com/product.php?id_product=457
Try contacting George Ashe, he may be able to help out, plus I recommend you post your question on the p15-d24 website, you may be quicker answers
Hope this helps,
No help from me but:
I have the switch attached to the steering column plus his actuating part on the trans lever column:
it is a nightmare to readjust every dozend times used...
Gaby51
Hi Friends,
For safety's sake, I want to install Reverse Lamps in my '54 Belvedere.  At this point, I have all the parts EXCEPT the Reverse Switch that screws into the Transmission!  My Plymouth also has the OverDrive unit made by Borg-Warner, so if anyone out there knows where to get a switch that will fit, I'd very much appreciate hearing from you. Thanks.  :)
George
