Support for early model Plymouth coupe trunks
Started by SD Glenn, March 18, 2012, 04:12:55 PM
SD Glenn
#5
Just curious, has anybody tryed the support brackets on their Coupe? and how did it work for you.? Works great on mine.
Just curious.
SD Glenn
SDGlenn
kimmc
Hey Glenn.  Thanks for your post.  I have seen these brackets/hinges....good thinking.  I will check these out.  Thanks again.  Kim
Good job, SD Glenn,
I like your thinking...
SD Glenn
Check this out, let me know what you think.  A couple pictures attached.  I found in our local Menards Store, Hardware store, Surplus store (all three stores) supports for the 28-29 model Plymouth coupes trunks. They have both right side and left side supports. They are hinges for woodworking, benches lid, or whatever, however they are strong enough to support the trunk, and attach real close to original. Paint them black and you may be in business. Cost $4.00 each. They work great, one problem I found ... it is kind of a nusance to reach around both sides of the trunk to release them. I'm lazy. lol   I did not build a lower bracket, just drilled a hole in the drip rail for the bottom support area and attached there. (you note I am not a person that requires 100 % original, just functionality.) It works for me.
I measured 14 1/2 inches for the top and bottom location to center. The bottm is measured from the top end of the drip rail (see picture) The lid side is measured from the 2x2 across the top of the trunk lid. If you want it to raise higher shorten up the measurement. Hope this helps some of you.  I threw away my broom stick.
SDGlenn
