Horn button wire
Started by pondcarp, April 29, 2006, 06:07:14 PM
pondcarp
 :)  Thanks to all I found the hole and you are correct it is dasier to run it up from the bottom.  Now I am missing 2 pieces on the one piece type.  The contact spring, insulator, and screw.  May I will find them or can buy them if someone wants to sell them.
Ron "pondcarp" Holloway
Don St Peter
When rewiring my 40 Ply, I ran a piece of bailing wire thru the column ( steering wheel side ) and it found the hole in the bottom side by itself. I then attached the horn button wire to the wire and pulled it through.
Don
Don
What year and model?
On my 1933 PD the hole is pretty easy to find. As I recall it is easier to feed the wire up from the bottom than down from the top. But then again, it has been years since I rewired my car and my memory is not what it once was.
pondcarp
 >:(  OK I give up, the manual says to run the wire down the center of the steering tube.  I do that but I have not been able to find a hole to get the wire out of the bottom of the tube.  Help please I am at a loss.
