1941 Plymouth Paint Code location?
Started by bgrumka, November 21, 2011, 05:53:04 PM
The paint and upholstery codes are going to be numbers so probably won't do you much good.  The paint code is probably more helpful as it can be referenced to the color chips....
bgrumka
Quote from: RC Drown on November 23, 2011, 10:40:22 AM
That is the same reply I got by email this morning
Too bad, I was hoping they might have changed their minds once they had received multiple requests.
I posted the message to your post just a minute or so ago as well.   Looks like it's still $45 for the full Build Card.
bgrumka
I contacted the Chrysler Historical Museum Archives via email I obtained from their website and this was their response in acquiring  Build Records for my Plymouth, or any Plymouth/Dodge/Desoto/Chrysler/Hudson/Nash/Rambler/Willys-Overland car 1930-1967...
11/23/2011...
Unfortunately, at this time we are unable to research your request.  The archives has temporarily suspended answering research requests so that our staff can concentrate on several large projects.  We hope that these projects will enable us to provide faster and more comprehensive services to our customers.  We anticipate being able to answer requests beginning in early February of 2012.  Please contact us at that time
http://wpchryslermuseum.org/newsroom.do?id=390&mid=135&mid=146
bgrumka
#8
Quote from: TodFitch on November 22, 2011, 12:07:47 PM
Quote from: bgrumka on November 22, 2011, 11:09:34 AM
First, I'd like to say thanks to all who responded to my query and with such dispatch!!
I have a paint chip set for 1941 Plymouth, but seeing the colors online and perhaps an example of the paint on a car will help, so thanks for the two websites on paint chips.
Does anyone have the information on how to get the "Build Card" via the Chrysler Historical Collection? Either an online site or address/phone and cost?
I know how to get that information for pre-war Cadillac/LaSalle but not for Plymouth.
And.... "from published documents what model a car is and what factory it came from by just looking up the serial number"? Is there a site for this? I've tried searching and came up empty.
Thanks again!!
Sorry, I should have linked to pages on my web site. For build card information see http://www.ply33.com/Misc/buildcard
For serial number lookup see: http://www.ply33.com/Misc/vin
P.S.: Just did a Google search for "plymouth serial number lookup" and my page came up top of the list. What search string were you using to look for Plymouth serial numbers?
My search was on "Plymouth VIN number lookup" and thus the poor results.  Thanks for all the updates!! Great information contained in all!!
I just went to your site (http://www.ply33.com/Misc/vin) and discovered that, based on my previous search results, I had been there already. The probelm I guess was on my end, not realizing what your site represented, through ignorance and not giving sufficient time to understanding what it represented, and the subsequent value.
Thanks again!!
Well there is a serial lookup on the P15 D 25 board but it's for 46 through early 49, and yes you can tell the assembly plant and a date range by the serial number.  There were three assembly locations Detroit, Evansville, in, and LA, Ca.
I believe you can start the build card facsimile process by contacting the Walter P Chyrsler Museum in Detroit.  Start by looking up the website there may be a link from thir home page.
there are several folks with 40 and 41 Plymouths who are members of the P15 D24 forum, you might want to peruse that site for info also.
bgrumka
Thanks again!!
The color chip chart on autocolor library shows 5 grays for 41 cars and one for commercial vehicles.
Airwing, Gunmetal, Gunmetal Poly (metalic) Flight gray Poly and flight gray medium poly
http://www.tcpglobal.com/autocolorlibrary/aclchip.aspx?image=1941-plymouth-pg01.jpg
enlarge the thumbnails to get the color codes.  I believe the medium poly refers to larger metallic pieces that the regular poly.
Chrysler did not encode build information into the numbers back then: They were just sequential numbers for different build runs. You can tell from published documents what model a car is and what factory it came from by just looking up the serial number. But that is about it.
Body numbers are separate sequence numbers depending on the body plant and I've never seen references tying those to specific paint or trim. Engine numbers are also sequential with a engineering model code prefix.
If you are looking for information about the paint and upholstery the car had when it left the factory, the only way I know to do that is to send your car's serial number (located on the front passenger door hinge post) to the Chrysler Historical collection along with some money to get the "build card". That card will have the original body number, original engine number, paint & trim codes, options, etc. on it.
bgrumka
Hi,  I'm looking to find out where on the 1941 Plymouth the paint and trim/interior codes are located. And/or how to decipher if it's embedded in some number.
Trying to figure the original color of my Plymouth. Looks to have been some type of gray, but would like to know the color exactly.
Although perhaps close, the car is not currently the original color.
Thanks, Bob
