1930/31 Plymouth Chrysler PA/PB 4cyl 4 blade fan
Started by CollectorsChoice, November 09, 2011, 05:32:07 PM
CollectorsChoice
The 4 blade fan specs:
14.75" Overall diameter
4 mounting (5/16") bolt holes on a 2" dia circle
1.125" center (pilot) hole
http://www.ytmag.com/parts/
Check out this site, they may have a fan.
Another place to Check is Dave at Fat Fendered Relics, if he doesn't have one, he may know where to have you inquire
Hope this helps,
CC,
It seems odd that not even a fan for a tractor will come close to being suitable.
I do not know what tractor places you have checked out, but have you gone to a
"mom & pop" type of tractor supply store?
Other than being about 14 3/4" long, what other specs does it need to meet?
Like, diameter of the bolt pattern, etc?
CollectorsChoice
I am in search of a 4 blade fan for a 1930/31 Plymouth PA/PB 4cyl car. I have checked numberous companies with no luck. The diameter of the blade (end to end) is 14-3/4" and it has 4 bolts. Looks like a fan for a tractor, but no luck their either. If I could come close, I could reindex it to fit (the one I have broke a blade which was sent into the radiator). Any help would be much appreciated.
