Spark Plugs & Ever-Dry Kit
Started by Gaby51, August 02, 2011, 10:06:35 AM
Gaby51
Quote from: Lindsay McConnell on August 03, 2011, 09:35:48 AM
Looking at the factory Installation Instructions sheet that is in one of the "MoPar EVR-DRY Sheilding Service Package" I have in stock this is what they say on line three.
"Remove and discard spark plug gaskets as they are not needed and (underlined) Must Not Be Used With Spark Plug Mounting Bases."
Thank you very much Lindsay, that's just the info I was looking for!!!  I knew some had the answer.    :)
Lindsay McConnell
Gaby51
Quote from: plym_46 on August 02, 2011, 10:53:02 AM
no istallation instructions i the kit???
Nope, just the parts.  They're easy to install, I'm just not sure about the Crusher/Washer.  :(
Gaby51
  Another "dumb" question from a newbie, but I recently bought the "Ever Dry" kit to install on my '54 Plymouth's engine.  Along with the kit, I also bought new spark plugs, and it occured to me tI didn't know what to do with the spark plug's crusher/washer!  Do I have to remove those washers when using the Ever Dry metal cups?  Do I need spark plugs with a longer reach/seat?  Do I have to tighten them more or less or the same as if I didn't have the Ever Dry kit?   ???
  It all seems so simple, but since this is my 1st old Plymouth, and flat head engine, I honestly don't know how to do some of these "simple" tasks correctly.  Any advice will be greatly appreciated.
Thanks.  :)
