1948 Plymouth P15 vent windows
Started by flemingrj, June 17, 2011, 06:24:16 PM
This is off my '41 coupe when I took it apart. I think as long as you have the two special washers above and below the bracket and the spring in the correct place it will work. Make sure the spring is tight enough. Your's may be differnt too?
flemingrj
Gentlemen here is a question that also shows my stupidity. I once removed both vent windows from my P15 in order to replace the rubber  gasket or weather strip. Upon reassembly I must have put the spring , washers ,etc in the wrong order. The windows no longer click and hold open in different positions. If any one knows the proper order of assembly of these parts please share this info with me. I have owned my car for over 30 years . What I dont know about it would fill a large book.
