The "Wayback Machine"
Started by RC Drown, April 06, 2011, 11:50:48 AM
Thanks Pat, but boy it was an ordeal getting her under motion again, my fault, but finally she is driveable again and that is what counts
Bob,
Glad to hear that the Wayback Machine is up & running.
The "Wayback Machine" was laid up almost a month, while we replaced the pionion seal, inner and outer axle grease seals, real brake lines and both rear wheel cylinders.  So this morning Cooper, my wife, and I went for a ride up in the mountains to take these photos of a covered bridge that was built in 1860.  Just a nice ride on back roads in the "Wayback Machine of approx 30 miles round trip.
I hope everyone is having as great a day as I am,
Thanks for posting the links to the photos. looks like a good aray of old vehicles there and nice weather also
Thanks, Boys, first thing will be compression test. I suspect a valve sticking in # 5 cylinder. Changed Spark plugs and tested spark on every cyl.
Ride home Lake Achensee-  toD?sseldorf  was 450 mls without problems, made 1/2 alps, Spessart, Taunus, Westerwald and  Siebengebirge mountain ranges on Autobahn with ease and 75 mph with throttle 3/4 open. We had 1150 mls in  all, 250 crusing in the Austrian Alps.
BMW Isetta (Front door only!) plus Plymouth  with my wife and me behind the trunk
http://www.flickr.com/photos/alpbachtal/5817975819/in/set-72157626773271773
Healy plus VW 1600 plus me at Ply?s door
http://www.flickr.com/photos/alpbachtal/5818543240/in/set-72157626773271773
No time now to put own pics, post will follow.
Greetings from D?sseldorf!
the spark plugs are the first thing i would check , change them round and see if it makes any difference to what cylinder is out , if it makes a difference the plug is faulty , if no change i would give it a compression test , to me it sounds like a blown head gasket.
Rex
CHS
Go,
Not sure if you found the problem yet, so here is a coomment on what happened to me. I was driving my car at a higher rate of speed than I normaly do. When I stopped I noticed I had a miss in the engine. I found one of the cylinders was not firing. I pulled out the spark plug and found a piece of carbon lodged between the electrodes. I cleaned the carbon out put the spark plug back in. When I started the engine I had all 6 cylinders fireing again.
I hope your fix will be as easy.
Happy Motoring!
Go, thanks for sharing the sites, I hope the problems with #5 isn't too serious
Love Your postings, Bob!
We are  plymouthing in Austria?s Alps (Achensee - Tirol). Past Friday, on tour with some 30 other oldtimer cars and 4 weighty passengers in the Ply, I had to pause 10 minutes due to little overheating. Didn?t bring it?s usual performance nor ran properly.
Sunday I checked ignition etc: seems to run on 5 cylinders only (no diffference when taking # 5 spark cable off). Maybe some valve problem.
Can?t solve it here, so I drive carefully this remaining holiday week.
Makes easily its max speed (75 mph) comfortably, but lacks power in lower rpm in the mountains.
Will check valves plus rod bearings next week.
Sorry, can?t put pics here in the hotel?s computer.
so, some Links: Hotel site doesn?t show the perfect underground car garage (with electric plug for my batteries charger - I have 2 batteries, but only one can be charged by car generator)...
http://www.travelcharme.com/hotels/fuerstenhaus/fuerstenhaus-bildgalerie.html
nice arial foto, the hotel is left, where the ship is starting
http://www.tradebit.de/filedetail.php/131948529v7730621-luftaufnahme-gleitschirmflieger-achensee-tirol-oesterreich-europa
I love to drive on these beautiful streets....even in the rain of today
Greetings! Go
Sebastiano,  Thanks for the comments,
Sebastiano
To be tehre, in those nice places with my two Plymouth could be only a dream
My Plymouth 29 U Touring or my P8 coupe?.....
to spend time in the wood with the nature and Ply...
Nobody can stop my dream, and dreaming perhaps...
Very nice pics Bob, send when you have, it is nice to share with us this memories
Sebastiano
Sebastiano - Italy
Pat,
No rain here the past two days, but today they are calling for strong to Severe thunderstorms.  So far this month we have had 12 out of 26 days with rain and over seven inches of rain in those 12 days.
Cool photo, Bob. We got 1.2 inches of rain at 5;30 A.M. and more this evening, with storms.
Cooper and I took advantage of a nice day, NO RAIN, found this covered bridge that we didn't even know was in our area
Bob-
The bottom photo reminds me of the (former) one room schoolhouse that I was living in when I married Diana. We moved out after 3 months; not enough room for her stuff & my stuff....in those days (1973) we had 9 (elderly) cars; 8 of mine and one of hers; whichver car started is the one that we drove...
We have had upwards of five inches of rain since last Saturday, there was a lull in the rain yesterday, so I was able to get the lawn mowed before I had to ask a farmer friend to use his mowing machine........  We ended up having Thunder storms last evening, and today it has been rainless, but again, strong thunder storms are possible.  To make a long story short, Cooper and I took advantage of no rain today and went for a ride in the "Wayback Machine"
Sebastiano
Very nice, Bob,
fantastic photos
bye
Sebastiano
Sebastiano - Italy
SD Glenn
Great pictures Bob, love your country side.  We have some bridges also, but no one ever takes pictures of them. Gas is still $3.78 in SD, I'm sure as soon as they hear prices are higher out there they will raise them here too.
SD Glenn
SDGlenn
Pat,
Thanks for the comment.  Glad you had the '36 out on Friday :)  I filled the Plymouth up this morning at 4.11.9 a gallon :(
Cool photos, Bob,
We have a covered bridge about 30 miles from us, but I don't get over that way too often. Took the '36 for a 10 mile spin on Friday; gas is over 4 bucks a gallon now.
My wife, Cooper and I took advantage of a nice day with no rain, and went for a ride in the "Wayback Machine"
No such luck here today, we have had strong thunderstorms along with an inch and two tenths of rain since 5am. All totaled we have had four inches plus of rain this week.  All that considered, we are still very lucky compared to Alabama and Georgia this morning
MRR41 COUPE
Love pictures of cars with waterfalls, Weather is sunny near Chicago today, Drivig season is about to start.
SD Glenn
You sure have beautiful country out there, I love it. Beats the hell out of the flat lands I live in. LOL
Glenn
SDGlenn
MRR41 COUPE
looks like cooper had a really long winter
Good photos, Bob. I especially like the one by the waterfall; more scenic than our corn and bean fields.
Cooper and I were out and about this past weekend, my niece "doctered" these two photos I took, just had to share, plus I added one that I took by the water falls.
No old car driving weather since, very foggy and lots of rain, not to mention abnormal temps for this time of year
MRR41 COUPE
Hope you get a nice spring weekend for driving, maybe more trees will be in buds.
We had over 70 deg. F on Sunday, today we had only 55. Too cold for convertible. As no rain and sunshine, today I made my trips in Peugeot 504 4dr. from 1978. Doesn?t get  out of the garage so much times, so I took the chance
Greetings and hoping for sun everywhere. Go .
Pat,
Glad that you were able to get the '36 out for a spin yesterday,  Cooper and I put a few miles on the "Wayback Machine" yesterday also before the rain arrived in the evening.
Today it is very windy with temps in the low 50's with light drizzle, suppose to have a nice Thursday and Friday, but time will tell
Hey Bob,
Our Spring has been very similar to yours; we probably get our weather a day or two before you. Took the '36 for a 10 mile ride today, life is good.
Believe it or not, these photos are in Spring time here in the Catskills.  It has been a very cold wet Spring so far, the lilac trees are begiinning to bud as are the soft maples, but that is about it  Yesterday we had temps in the upper 70's, today back down in the 50's. overcast and windy
MRR41 COUPE
You must have some spring pictures about ready to post?
Sorry to hear about your Mom, I lost my Mother at age 55 to colon cancer 26 years ago this June
41PlySD
I always thoroughly enjoy your photos Bob but I have not been on any forums lately due to losing my mom in late March.  :'( I'm focused on getting our old homestead cleaned out now. Keep those photos coming though Bob...they are enjoyed by tons of Plym. fans...We have no idea of how many people we touch with them.
RobertKB, this is one of my favorites, hope you don't mind
RobertKB
The middle one is my favourite. Cool old car, cool old barn, cool old road, just plain cool!!
1948 Dodge D25 Club Coupe
Love Those Old Mopars
Greg, good photos, always great to see the old Mopars out and about
Thanks for sharing
And a couple more
Took a 150 mile jaunt today and went by Delta Lake near Rome, NY.  the lake was originally impounded to provide water for regulation of the Erie Canal.  The original dam has been rebuilt a couple time last in the 20's or 30's, guessing the ridge over the outlet is from the same time.
