1948 Plymouth
Started by patsy13, March 28, 2011, 06:32:58 PM
Quote from: bigaadams on March 28, 2011, 07:31:55 PM
142 ft. lb. minimum...no max stated...so 142 and a grunt..
My torque wrench is pretty well maxed out at that point. But I have bar about 16" long and weight 190lbs, so if I put all my weight on the bar with it horizontal to the ground that is pretty close to 250 ft-lbs. I guess I might have tightened mine too much. :)
bigaadams
patsy13
I would like to know if anyone has the torque specifications for rear axle nut holding rear brake drum
on 1948 Plymouth.
Thank you.
