Oil Presure Question for 4 cylinder Plymouth Owners
Started by johnRFain29U, January 17, 2011, 10:04:17 PM
GWR
Hi John,
1. My car is a 30U Coupe, Engine # U227832. Serial Number on the car is 1525651 and was built about June 15th to 18th of 1930.
2. The oil pressure gage is attached on the left rear under the starter.
       I have a couple oil pumps and have had mine rebuilt, and there is no place on any of mine for an oil pressure line, that I know of.
3. I have mine adjusted to run at about 40PSI at speed and it idles at about 20PSI.
Gary
GWR 30U Business Coupe
        67 Fury III 4drHT w/383
SD Glenn
1) What year is your car? I have the 1929 Plymouth coupe.
2) Where is the oil pressure line connected - to the oil pump or to the oil gallery under the starter?
My oil pressure is on the pump, there is not even a place close to the starter to hook one up. Is that strrange? I will have to look closer maybe.....
3) What is the max oil pressure when run at operating speeds - cold and hot?  Hold close to 40 idling and driving, however, I have only driven it up the block and back,. LOL
Glenn
SDGlenn
johnRFain29U
   I am rebuilding my 29 Plymouth engine (SN U50105).  My car was manufactured approximately May 15, 1929. On this engine, the line to the oil pressure gage comes off an oil galley port on the left rear of the engine under the starter, near the rear main bearing.  I obtained a 1929 parts engine (SN U29287) that was manufactured earlier than my engine.  On this earlier engine the oil line to the oil pressure gage comes directly off the oil pump. I am using oil pump from the parts engine on my rebuilt engine.  This has allowed me to place a second after-market oil pressure gage in my car, with the "new gage" showing the pressure at the pump, and the original gage showing the pressure at the other end of the oil gallery.  When I run the engine, the difference in oil pressure between the two is 5-10 lbs when running at operating speeds (30-40 mph).  At warm idle the two register about the same (~20 psi).  Also, the gage measuring the oil pressure at the pump fluctuates quite a lot, while the oil pressure measured downstream on the original gage is much more steady.
    Now - I am trying to set the engine oil pressure.  The "May 1929" manual states the oil pressure should be 35-40 psi at normal operating temperature.   I have set it so the oil pressure at the original downstream gage is 32 psi when warm, and the pressure at the gage is about 38 psi. When the engine is cold and run at 30-40 mph, the pressure at the pump is about 45 psi - until the engine warms up.  I hope this is OK?
     My survey question is:
