Where to get replacement coil?
Started by gtconboy, March 09, 2010, 09:12:20 PM
gtconboy
Thanks, guys. I'll check out both ideas.
GTC
George Conboy
Rochester, NY
'53 Belvedere
'40 PT105 Pickup
WRSW32A
SORRY MY ERROR. THE CORRECT SITE IS: (www.atwaterkentmfg.com) AGAIN, GOOD LUCK.
W.W.
WRSW32A
Contact (www.atwaterkent.com) They can rebuild your existing coil. GOOD LUCK!
W.W.
CHS
I have a 55 Plymouth with a 6 volt coil mounted on top of the plug wires. On my car the coil bracket has a scew and nut you loosen and the coil can slide out. You might want to find a coil bracket from a 55 Plymouth.
gtconboy
I have a bad coil on my '50 Windsor - not Plymouth of course but I have a '40 PT105 and a '53 Belvedere so I thought I could ask a question about a similar car.  Anyway coil is bad, and I am not having any luck getting a replacement that has the bracket spot-welded to the coil body so the coil can be mounted atop the plug wire loom.  Tried Bernbaum and Roberts but they do not have. Would appreciate any suggestion and am a ready buyer if you have a spare to sell.
Thx, Gerorge
George Conboy
Rochester, NY
'53 Belvedere
'40 PT105 Pickup
