1933 Plymouth PD Headlights
Started by 3chris9, February 02, 2010, 05:44:19 PM
Can anyone define a 1933 PD headlight body other than chrome plated brass Twilite?
Does anyone know if there is more than 1 type of 1933 brass PD headlight
0 (0%)
Does anyone know what a 1933 Dodge headlight looks like or dimensions
0 (0%)
Total Members Voted: 0
GWR
I have been working on putting together a simple chart that shows all the lenses for Plymouhts from 1928 through 1939. As you know basically in 1940 everything went to sealed beams.
According to my information;  1933 US built  PC, PCX and PD's had a Plymouth part #614456 which was a Twilite flat lens part #915283, which was a convex lens 8 3/4" X 7 3/4".
I also show and Atlas lens GM4456 as an aftermarket replacement.
     Canadian built PC, and PD had a Plymouth part #378866 which was also a Twilite lens with a part #8892, this was a convex lens 9 5/16 X 8 1/2".
I just acquired a set of Guide catalogs and they give numbers as follows:
Headlight assemblies - Plymouth 1933 PC  - 654-AX  Chrome Twilite Double bulb $6.60 (just thought I would add that for fun)
                                                          - 654-BX  Black        "        "          "   $4.75
                                              1933 PD - 828-CX Chrome Twilite Double Bulb $6.60
                                                           - 828-BX  Black       "        "         "    $4.75
This catalog confirms the Twilite #915283 lens number, but it also gives the notch positions as 0 - 60 - and 300 degrees. Oh, the price for the lens was $.90.Don't we wish. I also confirms the Canadian built with a lens #8892.
It also gives the following parts for the PC Standard (US ONLY)
   Gasket - Lens Seal #6083
   Spring - Lens Retaining #914255
   Molding only - #918277
   Reflector - #915223
   Wiring Assembly - #918284
For the PC DeLuxe (US ONLY)
   Instead of Molding it says Door Only - #915284
   Reflector - #914714
   Wiring Assembly - 915293
Hope this helps. (or maybe it confuses the issue.)
Gary
GWR 30U Business Coupe
        67 Fury III 4drHT w/383
Maybe they are for an early PC.
Is there a Twilite part number on the lenses? Someplace I've got a listing of what Twilite lens number fits what application, I might be able to find it.
3chris9
I have a pair of headlights that are supposed to be 1933 PD but they are more rounded than mine.  They are chrome plated brass Twilite, does anyone know what a 1933 Dodge headlight looks like?  Also was there more than 1 type of chrome plated brass headlight used on the 1933 PD?  Thanks,  Chris
