Gas tank strap nuts & SS trim needs - 1955 Ply.
Started by Scott55Ply, January 13, 2010, 07:45:31 PM
Scott55Ply
Thank you very much for the tip & the eBay reference!  Scott
49plymouthclubcoupe
Quote from: Scott55Ply on January 29, 2010, 12:54:04 PM
Bob,
The gas tank strap sleeve nuts are no longer available.  Made one from a threaded rod coupler & replaced the broken tang to fit.
Where were you stationed in AK?
Scott Grundy
They are still available through Dave Kruse in California .........
http://cgi.ebay.com/ebaymotors/1935-1950-Plymouth-Dodge-gas-tank-strap-nuts-new_W0QQcmdZViewItemQQhashZitem19b9e751cfQQitemZ110493127119QQptZMotorsQ5fCarQ5fTruckQ5fPartsQ5fAccessories
John - Colorado
Scott55Ply
Bob,
Tried to send you pictures of our cars as I'm not sufficiently skilled to post such.  Your address didn't work.  I'm .
Scott Grundy
Scott,
Can you post some photos of your car?
I was stationed in Alaska from Nov '70 to Oct '71
Very beautiful state
Scott55Ply
Tod,
Oh good grief!  I knew that I had seen them advertised, ASSUMED eBay & then searched my files to no avail.  I thank you very much!  I'll order a pair this morning.  Thanks again for helping this gray head!
Scott Grundy
Fairbanks, Alaska
If you are a POC member then you should be getting the magazine. In the classified section in the back there is a fellow selling gas tank strap nuts. Are those similar to the ones you need?
Scott55Ply
This is my virgin experience!  Looking for a source of gas tank strap nuts for a 1955 Ply.  It's a tube about 1.5" long with a large nut on top & takes a 5/16" fine thread tang bolt.   Could also use a 3.5" tang bolt to fit.  Also need the right side rocker panel SS trim piece from a '55 Belvedere with Sportone trim & the left rear quarter panel SS trim piece that's in good condition from any 1955 model with two tone paint.  Been a POC member for several years & didn't know this site existed.  I'm delighted to have found you!  Scott
