Complete Overdrive, cables, etc for sale
Started by jd2ksilver, December 24, 2009, 02:35:57 AM
jd2ksilver
John Davies
Mountain View, California
jd2ksilver
Will fit Plymouth from 1940 thru 1954... and some Dodges
The complete Overdrive transmission with;
Governor
solenoid,
Kick down relays and push button set up on gear shift using circuitry by George Asche (12 volt set up, but I believe can be wired to 6 volt relays)
Lock out cable and handle.
I'll even negotiate the transmission shift linkage from the steering wheel to the tranny itself if you need it.
It has been in my car for about 2 1/2 years.  Works great, (but if you try to speed shift to from 2nd to 3rd it will grind)
Plenty of documentation some spare relays, solenoid.
You only have splice the wires I cut when dismantling from my car.  Wire set up will hard to mess up.
$950 complete, $50 for me to crate it in a good wood box for ground shipping.  Plus whatever the freight is to you door from 94040, about 85 lbs if I remember right.
John Davies
