30U rear end seal
Started by GWR, September 26, 2009, 07:27:03 PM
Gary,
The guy below has been selling these on eBay for some time now.? I don't remember buying anything from him but these seals seem to be more available then the Axle Seals.? Of course if you can get NEW rather then NOS it may be better when buying anything containing rubber.
The seller is Valley Vintage Autoparts
http://cgi.ebay.com/ebaymotors/Mopar-NOS-Oil-Seal-1923-1933-Plymouth-1933-Dodge-6-cyl_W0QQitemZ7990890061QQcmdZViewItemQQptZMotors_Car_Truck_Parts_Accessories?hash=item1dc4b4e4d&_trksid=p4506.m20.l1116
Good Luck,? Chet...
GWR
Found that mine leaks a little and am wanting to clean things up. Where can I find new ones, rejuvenate old one, or how do I replace with newer version?
Appears the nut on the yoke was loose (only hand tight) and came loose and caused the bearing to ride against the yoke and scored it really bad. Anyone have infor on what the clearances between the yoke and bearing should be, if any?
Gary -
GWR 30U Business Coupe
        67 Fury III 4drHT w/383
