What are these washers for?
Started by Carmen, April 07, 2009, 10:19:02 AM
Carmen
I have them on a key chain in the glove box, hopefully someday I will find out what they are for and where they came from. They must be some kind of specialized washers and since the car is running great I will assume all is OK.   I do want to thank you all for the input.
Carmen
they look like small fender washers, 1/4 or 5/16.  may be they were on the splash shields at one time and not replaced because they were hidden in the crud and just stuck there
Carmen
I was hoping that they are not from the engine. I did remove the front and two side splash shields from under the engine to clean up all the crud that was on top of them. Will keep them on a key ring in the car.
Carmen
They look like the washers used to hold sheet metal to either the radiator support or to the cowl. They are not from the engine.
Plymouth-guy
If they were covered in grease or thick dirt there's a good chance they'd been sitting somewhere on the engine for years and got bumped or jarred out. Just a theory.
An old car is just a car unless it's a classic MoPar!
Carmen
Guys, I'll even take a guess as to what they are for. All I did was replace the Carb, which I had rebuilt, replaced all of the hoses and that was it.
Carmen
Almost forget I did replace the vacuum lines for the power shifter
Carmen
As some of you may know I have been working on my 41 when I broke a bolt, anyway I was cleaning up after myself and I found these 2 metal washers under the car. Can someone tell me what they are for?
Carmen
