TomTom GPS unit for 47 Plymouth, 6 volt positive ground?
Started by EJParauka, March 03, 2009, 12:40:09 PM
Quote from: Go Fleiter on March 03, 2009, 03:43:42 PM...snip... Well, and than classic cars should navigate with classic maps... from 1951?....;)
Having local maps from the era of the car can be useful for finding good tours to take. At least in this area roads have changed a lot in the last 50 to 80 years and places that were once on the main highway are now bypassed. Just the type of place for touring through in an old car.
EJ, I have my TomTopm working on one converter 6 to 12 V but neg. ground both systems.
If You don?t find one for pos. ground, You can easily use it for pos. ground if You make shure not to ground it and attach it reversely.
These Units can get very hot, don?t put it in a plastic container to insulate it!
You must think of an groundless plug too. TomTom is plastic- no ground risk
I never tried it but based on my knowledge of electronics I suspect that it will not work and might damage your GPS.?
PS...? There are converters which will convert 6 vdc positive ground into 12 vdc negative ground.? Price around $70 to $110 depending on current needs (amps that is).
EJParauka
Will a TomTom GPS device work properly in my 47 Plymouth's cigar lighter, considering it's a 6 volt positive ground system?
